Show more attributes as a clickable text (react) using Arcade Element
4609
11
09-01-2023 05:18 PM
Ed_
by MVP Regular Contributor
I am trying to setup a popup such that I would like it to show more addresses (if greater than 2) as a clickable, like a clickable text (view more addresses). Below code is an attempt which opens up a new blank browser window in Experience Builder. Since the map is embedded in an Experience Builder app.
Purpose:
The popup should initially show only two addresses followed by a clickable text. If the user clicks on that text only then more addresses will show.
Desired output:
Current code:
/ Create a variable that is the FeatureSet of intersecting feature attributes
var Address = FeatureSetByName($map, "ADDRESS")
var intersectLayer = Intersects(Address, $feature)
// This variable will be used to track the number of addresses shown
var addressCount = 0;
var showAllAddresses = true;
var popup = '<h3>Property Summary</h3>';
for (var f in intersectLayer){
  if (addressCount < 2) {
    popup += `<b>Address:</b> ${f.FullAddress} <br><br>`;
    addressCount++;
  } else {
    //popup += '<em>More addresses...</em>';
    popup += '<em><a href="javascript&colon;toggleAddresses()">View more addresses...</a></em>';
    break; // Exit the loop after showing two addresses
// Function to toggle the display of all addresses
function toggleAddresses() {
  // Rebuild the popup content with all addresses
Question | Analyze | Visualize
Ed_
@KenBuja when you have the time, can you please have a look at it? Thank you 🙂
Ed_
Hi @KenBuja any ideas on this one? Thank you 🙂
KenBuja
MVP Esteemed Contributor
No, I can't figure this one out
Ed_
No worries @KenBuja if you come across something, please do let me know, thank you 🙂
Ed_
@KenBuja  is it instead possible to create a collapsible list of addresses in the popup? Like if the addresses are more than two then the third, fourth addresses and so on will be initially hidden and if a user clicks on a text or something only then the entire list of addresses will show.
Ed_
Hi @KenBuja can this question's answer help in some way to the code in my question? Like to somehow use the PopupTemplate.title or something similar?
KenBuja
That's showing the results of multiple features at the same location. That's built into the popup, as shown in this discussion.
Ed_
Good morning @KenBuja hope all is well, oh I see I guess I thought it would work in my case as well because of this, `property so you can show additional information by adding it to the title:` mentioned in that post's answer. Oh well I will keep on searching.
I don't know if it's possible to use `react language` and JS Script in Arcade Elements because I think this question might require these two.
Ed_
Hi @KenBuja happy Monday, hope all is well so, I did some searching and found an HTML snippet shown below, do you think this can help in what I am trying to achieve? Thank you so much time and help 🙂
<!DOCTYPE html>
<html lang="en">
<head>
    <meta charset="UTF-8">
    <meta name="viewport" content="width=device-width, initial-scale=1.0">
    <title>Popup Example</title>
    <style>
        /* CSS styles for the popup */
        #popup {
            display: none;
            position: fixed;
            top: 50%;
            left: 50%;
            transform: translate(-50%, -50%);
            background-color: white;
            padding: 20px;
            border: 1px solid #ccc;
            box-shadow: 0 4px 8px rgba(0, 0, 0, 0.2);
            z-index: 1000;
    </style>
</head>
<body>
    <h1>Addresses</h1>
    <button id="showPopup">Show Popup</button>
    <!-- Popup div -->
    <div id="popup">
        <h2>Selected Addresses</h2>
        <p>Address 1: 123 Main St, City1</p>
        <p>Address 2: 456 Elm St, City2</p>
        <a href="#" id="showAllAddresses">Show All Addresses</a>
    </div>
    <!-- Link section for the rest of the addresses -->
    <div id="restOfAddresses" style="display: none;">
        <h2>Rest of the Addresses</h2>
        <p>Address 3: 789 Oak St, City3</p>
        <p>Address 4: 101 Pine St, City4</p>
        <!-- Add more addresses as needed -->
    </div>
    <script>
        // JavaScript to toggle the popup and link sections
        document.getElementById("showPopup").addEventListener("click", function() {
            document.getElementById("popup").style.display = "block";
            document.getElementById("restOfAddresses").style.display = "none";
        document.getElementById("showAllAddresses").addEventListener("click", function() {
            document.getElementById("popup").style.display = "none";
            document.getElementById("restOfAddresses").style.display = "block";
    </script>
</body>
</html>
Original source code:
