shapefile compressing
4145
08-24-2011 06:53 PM
IrynaTalmazan
Hi there,
I'd like to add the shapefile, created in my map, to ArcGis Online map, but I cann't zip it for adding.   Can you help? Thanks a lot.
MikeMinami
Esri Notable Contributor
Most modern PCs have the ability to create a ZIP file built in...You might check Windows Explorer to see if you can do it.
Hope this helps,
Mike
