Set visibility range for a "Create Editable Layer" point feature.
1070
12-21-2011 09:59 AM
ChristopherCiancibelli
I would like to set the visibility range for a "Create Editable Layer" point feature. The exact location of these points is sensitive information so I would like to have point feature disappear at certain scale. Is this possible, or can you only set the visibility range for imported layers/features?
MikeMinami
Esri Notable Contributor
Currently you can't set the visibility range for editable layers in the Map Viewer of ArcGIS.com. It's a good idea though and we'll try to add this. In the mean time, you can edit your map in ArcGIS Explorer Online and set a visibility range, http://explorer.arcgis.com
Mike
Thanks Mike. From what I can tell, the edits that I perform in the ArcGIS Explorer Online do take effect  in the Map Viewer. Is this always the case?
