State shape polygons in arcgis online!
2613
12-21-2011 08:27 AM
UMPplant
I'm currently working in arcgis online making a layer with each state shape (polygon/area).  Each state will be seperate and clickable with a popup for each state.
Halfway through i realized that someone out there probably already did this same thing, however all the searches came up with only the boundaries, not the separated polygons
So my question is, does anyone have a shapefile or a service that has all the state polygons seperated?
MikeMinami
Esri Notable Contributor
if you want to associate your own attribute information with the states, a map service wouldn't work for you because you can't join your attributes to it. Here's a layer package I found of boundaries. You could export shapefiles from this, I believe, in arcgis desktop.
http://www.arcgis.com/home/item.html?id=540003aa59b047d7a1f465f7b1df1950
Mike
