Select swipeable layers when adding a swipe widget
3381
03-12-2021 08:00 AM
TimFavier
I want to add a swipe widget to my webapp. In the "configure swipe" menu, I can select only 5 swipeable layers, while my webmap has 9 layers. How can I make sure that the other four layers are swipeable too?
BernSzukalski
Esri Frequent Contributor
I'm not sure when using Web AppBuilder there is a limit to the swipe widget. But as an alternative you can try Media Map - it's one of the express apps that can be configured (in full setup) with a swipe tool and layer list that you can use to toggle layer visibility for swipe. I just did a quick test with 10 layers with no problems.
The app is briefly covered in Apps you can use to swipe and compare.
TimFavier
Thank you BernSzukalski for you answer. Regards, Tim
DeclanRiordan
This is useless to me as I need two widgets on the same app, while the Media Map only allows the swipe widget
TimFavier
Solved!! I just found out that you can only included published layers in your swipe, and not unpublished layers.
