Security Audit issues are there in My Application.
848
09-20-2024 02:23 AM
JyoshnaRani
Hi team,
I used ArcGIS SDK in my application. After auditing of my application they found few security issue.
1. Use of a Broken Risky Cryptographic Algorithm. ->
com/esri/arcgisruntime/internal/apachehttp/client5/http/impl/auth/k.java
Description :
The use of a broken risky cryptographic algorithm is an unnecessary risk that may result
in the disclosure of sensitive information. The use of a non-standard algorithm is
dangerous because a determined attacker may be able to break the
algorithm compromise whatever data has been protected. Well-known techniques may
exist to break the algorithm.
Impact :
The use of a non-standard algorithm is dangerous because a determined attacker may
be able to break the algorithm compromise whatever data has been protected. Well-known techniques may exist to break the algorithm.
2. Insecure WebView Implementation. -> com/esri/arcgisruntime/security/DefaultOAuthIntentReceiver.java
Description :
WebView ignores SSL Certificate errors accept any SSL Certificate.
Impact :
Insecure WebView Implementation leads to MITM attacks
I had below android implementation version.
implementation 'com.esri.arcgisruntime:arcgis-android:100.15.4'
Please check the attached images for your reference.
Kindly suggest me to what are the necessary steps or process to fix this audit issues.
Thank You,
Jyoshna
SimonSchütte_ct
MVP Regular Contributor
