Searching for hosted tile services causes UI to freeze
1695
05-02-2014 02:37 PM
SimonLiu
If you search an Open Data portal, and your results include a hosted tile service, the UI freezes and you're forced to reload the page. To see this, you can search for "China" on the following portal:
Test Portal
The search result (delivered in JSON format) seems to be coming back from the server correctly, but there are null values in the response that the JavaScript code doesn't seem to like.
Could this be fixed? Ideally, tiled services should be supported in the same way that feature services currently are, or they should be excluded completely when users are searching an Open Data portal.
by Anonymous User
Not applicable
Hi Simon,
Currently we do not support tiled services, and will look to error handle as well as support in the future.
Thank you,
Andrew
SimonLiu
Thanks Andrew. ArcGIS Open Data is looking very promising so far!
