Search configuration for web map will not show editable feature services
1057
7
11-07-2025 09:03 AM
LISARAYBURGodot
For some reason, when I used to set up my search configurations in map viewer, I was able to see ALL of my layers in the map.
Now, I am only able to see rest services that are non editable. So, all of my features that I have published with editing and query capabilities are not showing up as a layer for me to choose under the search configurations. This is breaking all of my search configs that I had previously set!
EmilyGeo
Hi @LISARAYBURGodot
Are you trying to set up search by layer for hosted features services in Online?
As long as the layer contains fields that are either text or integer and do not have a coded domain, it should work:
LISARAYBURGodot
They are rest services. They are text fields and they do not have a domain assigned to them. The layers aren't even available to pick from the drop down list.
EmilyGeo
Hi @LISARAYBURGodot, It sounds like the services are getting filtered out for some reason. Are you using Chrome? A recent chrome update might have reset the permissions. can you check to make sure this is toggled on?
LISARAYBURGodot
I use Edge
EmilyGeo
Hi @LISARAYBURGodot
I'm still not able to see the issue on my end.
Are you using Edge 143? If so, it could still be re;ated security issue from the chome update since its used in the backend.
Do you have a service that is shared with the public that you could share? or an sd with the layer setup? If you can share a link we could take a look.
Thanks!
LISARAYBURGodot
would there be something in my setting on EDGE that I could fix like Chrome?
Here is what I can tell you:
  • When I publish a layer from ARC PRO to the server, it will not show up in the search list if it is editable
    • It will show up when it's not editable though
  • When I upload a layer to AGOL from my machine as a feature layer (hosted) (zipped shapefile) it shows up in the search list
I am wondering if it has to do with permission or versions of PRO ?
I do not have a public layer that I can share that does this
EmilyGeo
Hi @LISARAYBURGodot
I'm sorry this is still giving you trouble.
I think the best thing to do is contact tech support so that we can help troubleshoot. Here is that link https://support.esri.com/en-us/contact
Thank you!
