???Scale bar??? in meter,
2001
02-16-2014 08:48 AM
JamalNUMAN
Legendary Contributor
I???m wondering if there is a way to set the scale bar to be in meter
[ATTACH=CONFIG]31491[/ATTACH]
Thank you
Best
Jamal
Jamal Numan
JohnPlunkett1
Yes there is.
In your organisational account. (You need to be an admin)
Select My Organisation.
Edit Settings
Map
Scroll down to Units, Select Metric. then select save.
If you are a personal user
Edit your profile and change units to Metric.
JohnPlunkett1
Yes there is.
Edit Settings
Map
JamalNUMAN
Yes there is.
Edit Settings
Map
Many thanks John. It works fine
[ATTACH=CONFIG]31506[/ATTACH]
[ATTACH=CONFIG]31507[/ATTACH]
Best
Jamal
Jamal Numan
