Saving Measured Areas
407
04-07-2026 02:08 PM
JaredSpring
I'd like to be able to save multiple measured areas to be able to compile a list, with total acreage displayed in a table. I don't see a way to currently save multiple measured areas at a time, when I measure one area and then try to start a new measurement my old one immediately is lost.
I am using ArcGIS mapviewer online.
IssyAmis
Hi @JaredSpring As far as I'm aware, this is not currently an option in the ArcGIS Online Map viewer. The only way to do this would be to create a new hosted feature layer for this purpose and calculate the areas in a field.
You might have more luck doing this in an Experience Builder application. You can use the Draw widget and enable measurement in the widget settings. You can then configure the widget to show all measurements in labels. You can also configure the drawings to be added to your Map Layers widget and in turn, can use this to add the values to a table.
Let me know if you have any specific questions around this and I will be happy to help further.
Issy
