Retrieve data from third-party API using Basic Authentication, display as feature layer?
6364
01-23-2020 06:11 PM
JackSilburn
Hi
I am curious to know if it is possible to do the following:
  • create an ArcGIS Online item/feature/application which calls a non-ArcGIS API endpoint,
  • the API returns a JSON response when queried,
  • the API also requires Basic Authentication.
The data is interpreted as an ArcGIS Online 'friendly' format (e.g. feature layer? Table?), which can then be added to Web Maps, Applications, Ops Dashboard etc.
JackSilburn
Hi Peter
I ended up following a fairly convoluted (and bespoke) process:
  1. I am using a linux server to run a python program on an automated schedule
  2. The program handles the API requests, using the Python Requests module, to return JSON data
  3. The program then queries the AGOL API, returning a list of GIS features and associated primary keys
  4. The program joins the two datasets from steps 2 & 3, and POSTs the completed table back to AGOL, via the UpdateFeatures API method.
I now have a feature layer which is updated automatically with 'live' data, which I can use in Web Maps and so forth.
I believe I tried something following your first link, but for whatever reason it wasn't working out.
by Anonymous User
Not applicable
Hi Jack Silburn‌,
Thanks for the post. Were you able to get this to work?
I think this question ultimately depends on the JSON response when queried. From this doc, if the response is valid GeoJSON then you would be able to add it to a web map and create a hosted feature layer: What can you add to ArcGIS Online?—ArcGIS Online Help | DocumentationImport data | ArcGIS for Developers
Developer Communities‌ would maybe have more to add on the authentication component.
Hope this helps,
-Peter
JackSilburn
Hi Peter
by Anonymous User
Not applicable
Hi Jack,
Thanks for following up on this - I'll go ahead and mark your answer as correct to help anyone else that comes across the thread; as you mention it is customized for your scenario but I suspect other folks have similar end goals.
If you haven't yet I would recommend checking out Notebooks beta and trying it our for some of your workflows - it provides access to the ArcGIS API for Python and general Python functions in the cloud.
Cheers,
-Peter
NaomiOmwebu
I am attempting to a similar task- but I am not able to follow your workflow. I want to call a non ArcGIS REST API, and  would like to view and query the live data in ArcGIS pro or online, as well as overlay other different datasets/layers. I am using Windows 10.
