Hello ,
i have used the iexpression here but i changed only the attributes name as my data and it works when i click on test ,i got the result that i want
https://github.com/Esri/arcade-expressions/blob/master/dashboard_data/JoinLayerFieldsToTable.md
but after i added that expression to my table ,when i check the table of the layer in map viewer classic , it has automatically added the new attribute as i want but it is showing object object in column.
i would like to show only the result values from the expression that i have brought from other table .
Thanks in advance
Hi @Sergio ,
The main thing I notice is that the Push() function doesn't exist in Enteprise 10.8.1. If you look in the Functions list, it won't be there. Push() was introduced in Dec 2020 and tracing back it first appears in Enterprise 10.9.
Instead add to your array using an older method (lines 3, 20, 21 introduced):
// Create empty features array and feat object
var features = [];
var featuresIndex = 0;
var feat;
// Populate Feature Array
for (var t in tablefs) {
var tableID = t["FeatureID"]
for (var p in Filter(polyfs, "HydroID = "+tableID)){
feat = {
attributes: {
FeatureID: tableID,
ModelID: t["ModelID"],
AddressCount: t["AddressCount"],
MAX_TSTime: t["MAX_TSTime"],
features[featureIndex] = feat;
featureIndex++
It's a little difficult without seeing your data, but for displaying one to many, I think the code needs to look like:
var keyField = $feature.keyField;
var polyfs = FeatureSetByName($map,"FC_polyfs");
var tablefs = Filter(FeatureSetByName($map,"T_tablefs - T_tablefs"), "keyField = " + keyField);
var features = [];
var feat;
feat = {
attributes: {
FeatureID: tableID,
features[featuresIndex] = feat;
featuresIndex++
var joinedDict = {
fields: [
{ name: "FeatureID", type: "esriFieldTypeString" },
{ name: "Name", type: "esriFieldTypeString" },
{ name: "ModelID", type: "esriFieldTypeInteger" },
{ name: "AddressCount", type: "esriFieldTypeInteger" },
{ name: "MAX_TSTime", type: "esriFieldTypeString" },
'geometryType': '',
'features':features
// Return dictionary cast as a feature set
return FeatureSet(Text(joinedDict));
So instead of looking through every table row, you're looping through every table row that has the polygon's matching 'keyField' (swap this for your matching field name).
