Reporting map service errors
3639
11
02-05-2013 06:12 AM
MattMillard
How does one report a suspected data error in a map service?
Matt Millard
JimHerries
Hello, thanks for reporting these findings.  A new version of the European cache is completed and progressing toward its release.  I know that we did a bit of work in this region at the scales you are reporting concerns.  I'll share your map of issues with the team to verify whether they are already addressed.
An option to be aware of:  the canvas map template is available for those who would like to build a better basemap for their country or local area, using the canvas map's various shades of grey, labeling approach, etc.
Thanks for taking the time to share these items.
Jim
Jim Herries
Senior Principal GIS Engineer, GIS Engineering Lead
ArcGIS Living Atlas
JamesCrandall
Vilmantas Alekna,
There isn't a specific item in ArcGIS Online for reporting feedback on the Light Gray Canvas basemap, so you can just post what you notice in these forums.
Mike
When the Light Gray Canvas basemap is loaded into ArcMap 10.1 and then attempts to remove it (right-click-->remove in TOC) will hang ArcMap and must force close.
Environment:
Citrix 3.1.0.64091
ArcGIS 10.1
Any info is appreciated.
James
