Replace table field's default value in a Hosted Feature Service?
996
04-10-2023 03:35 PM
Wolfgang_Grunberg_AZ_DFFM
How do I change the default value for a table field (has a domain) in an existing Hosted Feature Service?
  • AGOL's Data>>Fields>>Details interface allows me to edit domain entries (very nice) but I can't change the Default Value.
  • ArcPro's "Assign Default To Field tool" gives me a "000664: Invalid input: This type of dataset is not supported" error.
The lookup table is in a Many-to-1 relationship with a point layer in the same Hosted Feature Service.
Thank you for your time!
MobiusSnake
MVP Regular Contributor
I believe you need to use the administrative REST API ("Update definition") to do this.  This call is also available in the ArcGIS API for Python.
