Reordering Bookmarks - ArcGIS Experience Builder - Bookmark Widget
4078
9
05-10-2021 05:16 PM
RIOS
Hello
I'm using the ArcGIS Experience Builder and I've created a Bookmark Widget with 2 bookmarks. However I noticed I cannot reorder these bookmarks! So let's say I have a hundred bookmarks. I'd have to delete them all and add them sequentially every time there was a change in the order? 🤔 😑 This seems untenable... am I missing something. This was possible in the Web App Builder. I wasn't able to find any help in the bookmark documentation either.
Bob
DonnaMoreau
I agree with RIOS. I have 46 bookmarks and as I was going through them, I noticed a mistake that I made at bookmark 13. Needless to say, it's staying that way for now because I don't have time to fix it.
Donna
PashaBell
Any updates on fixing this one?
ZachBodenner
MVP Regular Contributor
This doesn't really help if you've already made your bookmarks in ExB but you can get around it by making the bookmarks in the web map and then using the display bookmarks from web map option in the bookmark widget config. Map Viewer allows you to reorder bookmarks, so it is a bit of work duplication but at least it's a little more future-proof.
Happy mapping,
- Zach
RobertTaylor5
Reordering bookmarks is an essential function.  ESRI please get this done!
LayerItOn
Just noticed this too, I would love some way to reorder the bookmarks.
Laura
by MVP Regular Contributor
Needed in AGOL and Portal!
GarthHoxsie-Quinn
If you go to the far left of the bookmark, you will see four dots that allows you to move the bookmark. I am aware that this post is from 2021 but so it may have been part of an update since then. Just wanted to make sure everyone on this thread was aware.
DonnaMoreau
Thank you!
Laura
I don't see dots. Can you elaborate?
