Reorder Waypoint Sequence for Plan Routes tool in ArcGIS Online
1253
11-19-2020 05:23 AM
ChristopherEby2
I have a waypoint layer that I am loading into a webmap in ArcGIS Online and I want to create a very specific route between the points. Right now when I run the Plan Routes analysis it returns a route but doesn't visit the points in the order that I want. I can't see a way to specify the sequence for the points in the routes, is there a way to do this?
I did find a way to do this in ArcGIS Pro by modifying the Sequence column of the Stops in the Route Layer and re-running the Network Analysis. However, I am running into an issue using that route in ArcGIS Navigator where it says "This route does not overlap with your map's extent." when I try to open the route after sharing it. However, even if I find a fix for that I'd prefer to have an easy way of doing this in AGOL without needing to use ArcGIS Pro.
