Removing numeric separators in legend/key?
1047
03-26-2019 06:50 PM
ErinWarford
When adding numeric data to ArcGIS Online, it automatically adds numeric separators after every 1000. I understand that I can change the settings so that the numeric separators will not be used in the pop-ups or attribute table, but this does not change the values in the legend/key. Is there a way to make sure that the numbers in the legend/key will appear without the numeric separators? I am trying to symbolize data by year, and I really just want it to appear as "2019".
I am adding a .csv to ArcGIS Online. I am using the free version, not the paid version. I have tried making sure that the field was formatted as text, but this did not solve the problem.
Any advice appreciated!
StephenM
If you're using unique symbols to draw the layer, you can change the labels in the legend by going to Change Style -> Options.
change style button in ArcGIS Online
style options button in ArcGIS Online
style options details in ArcGIS Online
KellyGerrow
Esri Alum
Another option is to select the field type of string or date during the publishing process when you want to display the year as a year and not a number. This will ensure that thousand separators are not visible by default.
-Kelly
