Hi guys,
I cannot edit my attribute table in ArcGIS Online. Each time I enter the number in a new field/column, it disappears after a few seconds. I did that last week with the other table/layer and I didn't have any problem. I have admin privileges, and all edit options are turned on (related to that feature service - layer). It is a relational table. Please can you help me?
Thanks in advance and regards,
Boris Badža
I'd suggest getting in touch with tech support or monitoring the edit request using developer tools to get a little more insight into the nature of the error.
Thank you so much Kelly, I was following your instructions and identify the error- code 1000 in applyEdits line. It says that one of my sync columns does not allow NULL values, but all the columns I managed are set to allow NULL values, and I don't see that sync column on my list of Fields. Please can you tell how can I reach out to tech support directly. The support links, that I checked, are always direct me on GeoNet community and I wouldn't like to continue bothering entire community with my problem.
Regards,
Boris
HI Boris,
You can contact tech support using one of the numbers at this link: https://support.esri.com/en/contact-tech-support
If you are outside of the United States, makes sure you select the correct country so that you connect with the right support staff.
-Kelly
