Removing field from popup when returns empty using arcade - agol?
870
01-17-2023 04:47 PM
Labels (2)
ScumBagsSurfer
I am trying to hide a field label within a popup when there is no value.
Only a few of my feature class has values for this field while others are empty.
Here is an example of a popup in the image attached.
I am trying to use arcade to remove the field label within the popup when the field is empty.
This is the code I have tried so far.
IIF(IsEmpty($feature.nt_legislationname), "None""inline")
nt_legislationname is the attribute I am trying to do this for.
Tags (3)
