Remove Pop-Up Expand/Collapse Button
574
05-21-2026 11:58 AM
alee_
I am trying to remove the expand/collapse button in popups for my shapefiles in Map Viewer. It provides no help for a user if they accidentally click on it as seen in the 2nd image. Is it possible to remove it there, or is there another way I can remove it?
JonM32
@alee_
I don't believe there is a way to remove this button. It's built into Map Viewer and is kind of standard unfortunately.
Cheers,
Jon
If this response helps or is the solution to your post, please consider marking it as a solution
SteveCole
Honored Contributor
Like Jon says, that is embedded functionality so there's no user setting to remove it. One alternative would be to use one of the Instant App templates which load popup content into a side column adjacent to the map rather than as a popup in the map.
