Related table data view in popup
2622
7
03-16-2023 07:24 AM
BarryG
Is it yet possible to publish a map service with a related table to AGOL, and view the related table data in a web map popup?
jcarlson
You can use Arcade to grab the attributes easily enough using the FeatureSetByRelationshipName function.
- Josh Carlson
Kendall County GIS
BarryG
Josh, I tried following that process but still did not display the related table info, but only the field name and object Object.
jcarlson
Well, once you have your FeatureSet, you need to grab individual features and work with them.
for (var feat in featureset) {
// do something here
Are you trying to get a single attribute from the related features? If there are multiple related features, how will you choose which to get?
- Josh Carlson
Kendall County GIS
bsklaohfl
Hi Barry,
I had this issue and hope to provide some insight with my code. The goal was to create a chart which referenced my related table data ("ADT_Data_Merge") with the related road ($feature.MRNLINKID). I created the related table between the ADT Data and MRNLINKID on Pro, but ended up needing to switch to creating a relationship class in order to export my map/relationship to AGOL map. Hope this helps a bit.
		// Set variable to MRNLINK IDS
		var Road = $feature.MRNLINKID
		// Set variable to related table (notice FeatureSetByRelationshipName)
		var Table = FeatureSetByRelationshipName($feature, "ADT_Data_Merge", ['Mean_ADT', 'Year'], false)
		// filter through table, matching the table's STATIONID with road variable)
		var AADT = OrderBy(Filter(Table, 'StationID = @Road'), 'Year')
		// this was copied and pasted from AGO community post, I only changed certain variables
		var chartValues = {}
		var chartNames = []
		for (var f in AADT) {
		        chartValues[Text(f.Year,'0000')] = Text(f.Mean_ADT,'###,###')
		        Push(chartNames, f.Year)
		return {
		    type: 'media',
		    title : 'AADT by Year',
		    description : 'Annual average daily traffic by year for this road',
		    attributes : chartValues,  // replace this dictionary with your own key-value pairs,
		    mediaInfos: [{
		        type : 'linechart', //linechart | barchart | piechart | columnchart
		        //title : '',
		        //caption : '',
		        altText : 'line chart showing traffic counts by year', //altText will be read by screen readers
		        value : {
		          fields: chartNames,  // choose what attributes to use in the chart
		          //normalizeField : '',  // the name of the attribute to normalize by or value
BarryG
Thank you folks.  I have decided to instead create a model that will update values in a feature class from the table instead, as we have the identical fields already in the feature class.
NorthSouthGIS
You can have a scheduled notebook run your model as a python script routinely in AGOL or enterprise
NorthSouthGIS
