Related Record Pop-up Support for ArcGIS Server Services?
2910
12
11-30-2022 08:51 AM
ColinBergmann
@BernSzukalski  In the November update of ArcGIS Online (What's New in ArcGIS Online (November 2022) (esri.com)), support for showing related records in pop-ups was enabled for the new map viewer, but only for hosted services :(. This is a big issue for us, as most of the projects I work on use Server services, and we cannot migrate to the new map viewer until this feature is supported. I can't seem to find any info on the road map for this so was wondering if anyone knows when/if related records in pop-ups will be supported for Server services. Thanks!
LaurenBallantyne
Hi all, related records are supported on non-hosted feature services in Map Viewer as of the 11.2 ArcGIS Enterprise/Server update (Q4 2024). The work to expand this support to include map image layers is in the works. Here's some information on configuration https://enterprise.arcgis.com/en/portal/latest/use/configure-pop-ups-mv.htm#ESRI_SECTION1_723223B95E...
ColinBergmann
@LaurenBallantyne Thank you, this is good to know! So this applies to enterprise portal, but is there any plan for adding support for related records for server services used in ArcGIS Online?
LaurenBallantyne
Correction: 11.2 was released Q4 2023*
