Reduce table size with external key join
1668
06-06-2021 11:10 AM
Jose_FranciscoSánchez_Díaz1
I have a huge feature table with several hundreds of miles records of GPS positions.
Every feature has X,Y, device number, and driver name.
Id is a small integer, while the driver name is quite large text.
The more logical approximation is to store id in the main feature layer and the names in a related table.
I don't find a good way to do it. I try to do it making a relate on arcgispro and uploading it to arcgisonline, but I need the name being available to make a filter into a experienced builder filter widget and this way is not available.
Could you help me with any idea.
Thanks!
Tags (3)
Tim_McGinnes
Hi Jose,
For info on publishing related tables from ArcGIS Pro, see these 2 links:
FAQ: Why is a related table not retained when publishing a feature class from ArcGIS Pro to ArcGIS O...
Publish hosted feature service with related tables - Won't work with ArcGIS Pro 2.0
For info on joining tables in ArcGIS Online see these two links:
FAQ: Does ArcGIS Online support joins and relates?
Join Features
Note that the last link says that you need to use Map Viewer Classic for the join functionality.
Thanks for the info  !
I can't use Arcgisonline map view joins because the point layer is updated every five minutes and I want to make the join permanent. Another issue is the credit consumption, the layer will be near 1 million points and the cost is huge.
I tried to publish the layer with the relate defined in desktop. It works and I can see the related attributes in the popup, but I need the name of the device that can be used to filter data in a dashboard and view it in tables.  The related fields are not available for this kind of visualizations.
The solution should be making a view of the layer getting the related fields from another table or something like that.
