"There was an error publishing this service" Feature Layer Error
386
04-23-2024 12:56 PM
MeganLapinsky
I have been working with a point feature layer in ArcGIS Online for the past couple of weeks now. All of a sudden, when I went to add another point to the attribute table, I can no longer access the Data tab table. It gives me an error saying "There was an error publishing this service". It has been perfectly functional up until now. I have been able to edit/add columns, as well as update and add new points. Now I can't even access the data. Is there a way to fix this or will I have to redo the layer? Any help would be GREATLY appreciated!
jcarlson
MVP Esteemed Contributor
Has the layer been republished / overwritten lately? That seems like an odd error message to suddenly appear.
Any chance the layer is public?
- Josh Carlson
Kendall County GIS
MeganLapinsky
What do you mean by republished? and yes it is shared as public.
Thank you so much for the response!!!
jcarlson
It's very common for people to "update" a layer by overwriting it, going through the entire sharing / publishing process over again. That's what I mean by "republish". Did that happen?
What's the layer URL?
- Josh Carlson
Kendall County GIS
MeganLapinsky
I do not believe I have overwritten it. When I add more points, I use the update button on the feature layer's overview tab and go through the add feature option. I did not change the share status when I've updated either (stayed public).
https://services8.arcgis.com/L8b6VQ1g6PaRvMUO/arcgis/rest/services/ReceiverDeployments/FeatureServer
