Question about Hosted Feature Services
7671
16
08-18-2015 06:30 AM
JamesBoggs1
I am trying to create a web app where I can use the search function to find parcel polygons based on their attributes. My understanding is that in order to configure the search feature it has to be a hosted feature service. How do you get the feature in your "My Content" section to be hosted services?
So far I have uploaded my shapefiles in a .zip and created a map using the shapefiles. I’ve also created a web app using the “Finder” template and added my created map to it. All of my attributes are there and they appear in a popup when I click on a parcel. But when I am configuring the app it says that “No find layer has been configured” and “No layers available. Check your web map for valid layers”. How do I actually host a layer so that I can configure the search feature?
I have tried configuring the feature search based on the documentation, but I do not have the “Find Locations” setting available under the application settings.
Also, I am using a 60 day trial of ArcGIS Online if that makes a difference.
Attached are screenshots to help explain my problem.
Thanks.
JamesBoggs1
Okay, I feel like a dumb dumb. I did sign up for the trial, but apparently I never clicked on the link in the email to complete registering for the profile. All seems to be working as it should. Thanks to all for your help and patience.
-James
LaneHowerton
Hey James,
Ok, took a look at the link. I agree, looks like the Finder app. So I did some testing on a shapefile I already had uploaded to AGO previously. Mine is already published as a feature service/layer and I do have the option to publish again if needed. Not sure why you don't have this option but in my testing I can't even create a map from the actual shapefile. The only option I get when clicking the Open pulldown is Download. When viewing the details of the feature service/layer created from the shapefile and clicking the Open pulldown, I get the option to create new map from this layer. I save the map and click Share and Create A Web App. From there I used the Finder app, configured to search the attribute I wanted and bingo it worked!  Shapefile Finder Test screenshot on Screencast.com
I checked what I said earlier about just enabling Feature Search from the shapefile details>Edit screen and from the feature service/layer details>Edit screen and neither gave me that option. However, searching within the app worked fine. I've had this happen before when trying to figure out why I couldn't enable Feature Search from the layer details page and my conclusion is that AGO has coded these two methods of searching features differently.
Long-winded I know, but said all that to say, I think Russ is correct in that your problem seems to be stemming from the fact that you can't publish your shapefile as a feature service/layer.
No, you should not need ArcServer to do what you wanting to do as long as your fine with periodically uploading updates for your maps.
Hope this helps,
Lane
JamesBoggs1
Thanks Lane,
Hopefully I can resolve the issue of not being able to publish my files and will be able to go from there.
Thanks, James
MatthewCarey
Can I suggest approaching this a different way? I just tried to step through it myself and it seemed to work fine.
- Start with an .mxd in ArcMap and symbolize the (locally stored) data as you want it to appear when shared
(You don't need a basemap, just the operational stuff)
- In ArcMap, sign in to AGOL
- Do file>share as a Service and step through that
-This will give you a Feature Layer in AGOL
-From the My Content page, hit the little down arrow next to the feature layer and say 'add layer to new map'
-Save the map when you're happy
-Choose Share>Create a Web App>pick the Finder template
When it opened, I was able to configure the Feature Layer for 'finding', and it worked.
Any help? I wise man once told me, 'always start with an mxd and publish it from ArcMap' and it's worked well for me so far. Hope it works out.
RussRoberts
Esri Notable Contributor
This will work if you are connected to an org account and have a role that supports publishing hosted feature services.
JamesBoggs1
Matthew,
I am stuck at the part where is says to choose a connection. When adding a connection how do I get my server URL? Is a subscription to ArcGIS Server required to do this?
Thanks, James
MatthewCarey
If you first do File > Sign In.... and sign in to ArcGIS Online, and that's successful (that menu item should then change to Sign Out  - <username> ) , you should then have the option of this:
File >  Share As > Service > Publish a service > Choose a connection and you choose My Hosted Services(<your org name which should be automatically in there>) then you change parameters as needed and hit Publish.
Hopefully this is what you get, maybe you have different options because of your free trial?
