Published feature layer missing features
7613
9
05-20-2015 06:07 AM
BradJones
I have a polygon layer that I keep trying publish to my ArcGIS Online account and it keeps leaving features off.  There's a total of 94 features in the layer and only 46 features are published.  I publish them through ArcGIS Pro and I have uploaded the zipped shapefile and get the same result.  I analyze the layer and I get no warnings or errors. Any ideas?
TimWitt2
ArcGIS Online is know to exclude features that have too many vertices. Did you try and run the simplify tool in ArcGIS Dekstop and then try to publish?
SepheFox
Is there any pattern to the features it's missing? Are they always the same features regardless of how you publish them?
BradJones
They are the same features every time.  I can't discern a difference.
TimWitt2
Brad,
Do those feature have an excessive amount of vertices?
Tim
BradJones
PUBLISHED.jpgORIGINAL.jpgOverall no.  But maybe relative to polygon size?
TimWitt2
BradJones
I will try to simplify the vertices.
BradJones
Also, the original data displays fine from feature layer created from the file geodatabse.  This is about 94 out of 1800 features.
TimWitt2
Looking at the screenshot, I am pretty sure it has to do with the complexity of your features.
BradJones
Simplifying the feature worked.  I didn't initially think this was the problem because the original data set published OK.  Thanks.
