Greetings.
I am using a very stripped down of this template here:
http://www.peoriacounty.org/GIS/
You can see that there is a slight formatting error in-between my "IL Legislature" and "Peoria Tweets" applications. I have looked all over this forum and haven't been able to figure out why those thumbnails are different. I am using Grid_8 to get the 2x4 layout but i just can't figure out this misalignment.
Any assistance is appreciated.
Is there away to have my map services (or web maps or web mapping applications) listed under the "Layers" bar? It seems only that only type=Layer (my content) is visible here. Per arcgis.com help, I should be able to save a rest service as a "Layer".
Yes, if you look in "/scripts/home/local.js" you will see where it says "type: 'layer',". If you remove the word layer from that, it should show everything in the group.
Yeah, there are a lot so i've attached them in a PDF. It's the first column on the left I believe.
fantastic...last question (for now).
The featuredlayers currently open via arcgis.com while featuredmaps open as embedded in my root URL.
I want to highlight all my flex apps in the featured maps section and have the featured layers list open my maps the same way if they were in my featuredmaps section.
my dev site
// BUILD LIST ITEM html += '<li><a title="' + data.results.snippet + '" href="'+obj.arcgispath+'home/item.html?id=' + data.results.id + '">' + data.results.title + '</span></a></li>';
if(data.results.url){ // BUILD LIST ITEM html += '<li><a target="_blank" title="' + data.results.snippet + '" href="'+ data.results.url + '">' + data.results.title + '</span></a></li>'; } else{ // BUILD LIST ITEM html += '<li><a target="_blank" title="' + data.results.snippet + '" href="'+obj.arcgispath+'home/item.html?id=' + data.results.id + '">' + data.results.title + '</span></a></li>'; }
I think I understand.
If you replace lines 142 and 143 on "/scripts/home/local.js" which has this code// BUILD LIST ITEM html += '<li><a title="' + data.results.snippet + '" href="'+obj.arcgispath+'home/item.html?id=' + data.results.id + '">' + data.results.title + '</span></a></li>';
with this:if(data.results.url){ // BUILD LIST ITEM html += '<li><a target="_blank" title="' + data.results.snippet + '" href="'+ data.results.url + '">' + data.results.title + '</span></a></li>'; } else{ // BUILD LIST ITEM html += '<li><a target="_blank" title="' + data.results.snippet + '" href="'+obj.arcgispath+'home/item.html?id=' + data.results.id + '">' + data.results.title + '</span></a></li>'; }
that will open the layers list with the application URL in a new window like you're doing with the featured maps. Some of them are just items and don't have a URL I see so they will just open in ArcGIS.com. You may be able to change that.
