Problems publishing a hosted feature service using an ArcMap document
1090
09-25-2012 01:12 PM
AllenRisley
Hello,
I am trying to publish a hosted feature service using an ArcMap document.  I am following the steps outlined in the ArcGIS.com online help: http://resources.arcgis.com/en/help/arcgisonline/index.html?ESRISessionID=gcH3DU2twah6UqqQuaRC2B6nez...
I have an ArcGIS Online organizational account (I am the Administrator) and I am running ArcMap 10.1 (Advanced).  I go through steps 1 through 3 with no problem, I am signed on to ArcGIS.com.  When I get to step 4 (Click File > Share As > Service.), I cannot choose "Service", as it is greyed out.
Any ideas why I can't publish this way?
Allen Risley
Academic Technology Support
California State University San Marcos
JonathanQuinn
Esri Notable Contributor
Are you in layout view?  Make sure you're in data view.  Is the Service option still greyed out?
JonathanQuinn
AllenRisley
That did the trick!  I didn't see that in the documentation.  If it isn't there, it should be.
Thank you very much for the quick response!!
Allen
