Problem uploading CSV file to Hosted Featured Layer
2397
11-12-2020 05:15 AM
NordicLeather
Hi, I have created a Hosted Featured Layer (Line Layer)
Then I try to add data to this layer from a *.CSV file (see enlcosed). But always get error message 'No compatible layer found in the transfered file'
What am I doing wrong.
jherman
Hello,
It appears there's some issues with the format of the CSV. For example, the field names are separated by semicolons instead of commas. When I open it up in Excel, they all appear in one cell. Also, it looks like most values are separated by semicolons instead of commas.
Josh
NordicLeather
Many thanks for your answer!
Yes you're right - seems to be some problem with CSV file.
But I have tried another way to work around and import the Excel file, but same Error.
1. Have created a 'blank' Line Layer, and then the Fields:
OBJECTIDGlobalIDShape__LengthCreationDateCreatorEditDateEditor
automaticaly are created.
2. Open this new empty Featured Layer and chooses Update data - Add data to layer
3. Choose 'Line_layer_test.xlsx* (see attached) and press 'Transfer and continue'
4. Get the same Error message 'Error no compatible layer found in transfered file'
Cant understand this. I'm very grateful for any help!
