Print widget errors
4666
10
03-27-2019 09:27 AM
RalphBradt1
When printing out of a web app using the print widget, I most often get the error "Unable to load //utility.arcgisonline.com/arcgis/rest/services/Utilities/Printing/Tools/GPServer/Export%20Web%20Map%20Task/execute status: 0". I can occasionally get a few prints, but  then consistently get the error. I can reboot my machine and sometimes get a few more prints, but not consistently. This is happening using Chrome, Firefox, or IE and, further, I'm getting it happening on two different machines. It also happens with similar, but different, web apps.I'm totally at a loss to figure out what's going on here.
KellyGerrow
Esri Alum
Can you share your application or web map? If not, try to get in touch with tech support.
-Kelly
RalphBradt1
The app is at: https://melc.maps.arcgis.com/apps/webappviewer/index.html?id=1ba88b34779a44ffba353a41c2df1942
I have since gotten it to print once at 50 dpi, but I'm shooting for 300 dpi, which I have gotten, but only on occasion
KellyGerrow
Esri Alum
Thanks Ralph,
Some optimizations have been made to help the widget load faster, but we are still seeing intermittent failures to generate the pdf. This could be due to the size of the data being input or a variety of other factors. For that reason I'd like you to get in touch with Tech support to look into the issue further.
Please let us know if you need help getting in touch with support.
-Kelly
RalphBradt1
It is kind of a funny deal. I have managed to get some maps to print out (hit and miss) but some refuse entirely. Some appear to have printed, but the PDFs have badly broken fonts. Is there a specific facet of support I need to contact?
KellyGerrow
Esri Alum
Get in touch with support using the contact information for the country you live in:
https://support.esri.com/en/contact-tech-support
Mention that you are using Web AppBuilder in ArcGIS Online and are having printing issues. They should get you to the right person.
-Kelly
RalphBradt1
Thank, Kelly! I'll do that.
ClaudiaGIS
I am using the print widget and it seems to work out well. But if I download the PDF then I get an error message saying the font is not found. It seems it happens when you try to get a map using a larger extent than the default. Is there a chance someone can please help me.
City_of_Edgewater__Fl_GIS_Div_
I'm getting something like that too, how do we fix this
ClaudiaGIS
What I see it has to do with the scale. If you create a layer with the whole zoom extent it helps. I know it is not a real solution but is kind of a workaround. I am looking at other option for printing. If you find a solution please let me know. Stay safe.
