Point dataset - Time Animation dataset is blinking
3273
7
07-22-2021 09:57 AM
JaredPilbeam2
The whole dataset blinks when the time interval changes. How can I fix this?
I have a point dataset that I've set up for time animation. I have the time interval set at two weeks (range of time is 8 months). And the symbol in the map is set on Unique Values for a field with more or less two different values (either 1 vaccine dose or two).
In Pro I have the following settings for the Time. The END_DATE field has null values. I did this to keep the points from visually resetting after each 2 week interval. The animation works fine in Pro.
However, it blinks in AGOL. I have time animation setting set as such:
RussRoberts
Esri Notable Contributor
Can you try viewing this in a 4.x app like Media Map? The time playback performance has improved with 4.x apps like New Map Viewer and others.
RussRoberts
JaredPilbeam2
@RussRobertsThanks for the idea. I tried creating a Media Map app, but for some reason it won't finish. I'll move on to the New Map Viewer and see if that helps.
**Update
I created the same map with the New Map Viewer and tried creating a Media Map through there. Same thing, it doesn't fully finish creating the app?
JaredPilbeam2
There's something wrong. I can't configure any new app. They don't finish getting created. But, it still ends up in my Content. If I select Configure it's a blank page. If I select View Application I get of view of Seattle for some reason (I'm in Illinois).
JaredPilbeam2
It must be something with Firefox? I switched to Chrome and now I can create 4.x apps!
RussRoberts
I'll take a look at the FF issue.
JaredPilbeam2
@RussRobertsIt's working in FF now. FYI.
JaredPilbeam2
@RussRobertsNow we're back to it not working in FF.
