Overwrite feature layer workflow no longer works
2098
06-21-2023 04:34 PM
JimMiller3
I have a feature layer I regularly overwrite with a JSON file to reflect new data. It's always worked fine.
That layer update workflow no longer works. I get the message that "This file type is not supported." (Screen shot below)
As a test, I created a new feature layer from a JSON file and it worked just fine. But when I tried to overwrite the layer a short while later, using the same file, I get the message "This file type is not supported."
The latest ArcGIS Online update changed the workflow to append data to or update data in a hosted feature layer, or to overwrite the contents of a hosted feature layer.
I'm concerned that the update eliminated the overwrite functionality. Can this be fixed? Thank you for any assistance.
Trying to import JSON file gives this messageTrying to import JSON file gives this message
MikeMinami
Esri Notable Contributor
@JimMiller3 This is working now. Let us know if you see any further issues here. Thanks.
MikeMinami
@JimMiller3 Thanks for letting us know. We'll try to get this fixed this week.
MikeMinami
JimMiller3
Great, thanks for your help @MikeMinami
