Overlapping labels issue
1307
08-26-2025 11:39 AM
ClintOffutt
For the last month or 2, I have noticed labeling issues where polygon labels are overlapping.  I was reading in  a recent post that Esri has changed from a deconfliction strategy project. They are working on exposing a static and none deconfliction mode within the labeling experience and detecting label deconfliction between duplicated/repeated layers.
My question is, is there any way to revert to the previous labeling engine?  Can we go back to a deconfliction stategy project?  I just don't see, under any circumstance, when a map designer would ever want to have multiple labels stacked exactly on top of each other??!  When is such a labeling strategy desired where the developers feel this is better than only labeling that layer that resides on the top of the table of contents?  I think it would make more sense to only have one legible label than multiple labels placed exactly on top of each other so that none of the labels are legible.
VenkataKondepati
Honored Contributor
You’re right stacked labels are rarely useful, and this is a result of Esri’s recent changes to the labeling engine. At the moment there’s no way to revert to the old deconfliction.
:small_blue_diamond: What’s new: Esri has introduced label deconfliction strategies (static, none) in the SDKs
LabelClass | API Reference | ArcGIS Maps SDK for JavaScript 4.33 | Esri Developer
 but these options aren’t exposed yet in Pro or Web Maps.
:small_blue_diamond: Workarounds for now:
:small_blue_diamond: Next step: Upvote the Ideas so Esri prioritizes exposing these controls in Pro and Web Maps:
Regards,
Venkat
Regards,
Venkat
Book a meeting with me:Get on a Call
Follow me on: LinkedIn
If this response helps or is the solution to your post, please consider marking it as a solution
ClintOffutt
Here is a recent post I made on another thread.  I guess my concern is more of labeling priority, rather than placement strategy (which I also want).  Can the developers at least go back to only labeling one layer or is that all part of the strategy that has been permanently implemented?  If you read my situation, scale ranges, etc. don't help because its all the same layer with different views set up for different label options by end users.
Hi, recently, as in the last month or so, there have been labeling conflicts on polygons.  I have a hosted feature layer, then 2 hosted views based off that layer set up for different labels in the web map.  Obviously, these features all have the exact same shape and extent, and therefore, want to label in the same spot (center of the polygon).  Previously, (I have had the exact same maps set up for several years), when multiple layers are turned on, only the top most layer in the table of contents would draw.  If multiple of these layers were turned on and had labels shown, only the top label would draw, then if you turn it off, the one under that would label, and if you turn off that, the main label would label.  Recently, however, the software is drawing all labels, overlapping, making a mess!  This has never happened before and I am interested in knowing what has changed and what can be done on Esri's side to rememdy the issue.  I am NOT interested in offsetting labels, that is not an option.  I just want to labeling engine to go back to how it was before and not allow overlapping label conflicts.  Here is a pic of 3 labels drawing right on top of each other:
VenkataKondepati
Honored Contributor
Hi @ClintOffutt,
You’ve described the change perfectly. This isn’t about placement tricks—it’s about label priority across duplicate/related layers. Up until recently, only the topmost layer’s label would draw. Now the labeling engine is rendering all labels from all layers, so you end up with stacked, unreadable text.
Unfortunately, there’s no way to revert to the old behavior—this is part of Esri’s new labeling engine. Developers have introduced deconfliction “strategies” (static, none) in the SDKs, but these options aren’t yet exposed in the Web Map/Pro UI. That’s why you’re seeing overlapping labels even when your scale ranges and symbology are set correctly.
For now, the only workarounds are:
  • Turn off labeling on duplicate hosted views
  • Convert labels to annotation in Pro if you need fixed cartography
  • Or use a single layer with multiple label classes instead of stacked views
The fix really has to come from Esri by restoring cross-layer label deconfliction or exposing priority controls. I recommend upvoting and commenting on these Ideas so the product team can prioritize it:
I know it is painful, but it looks to me that there are no options to revert the behavior.
Regards,
Venkat
Regards,
Venkat
ClintOffutt
Thank you for the thorough explanation.
VenkataKondepati
Honored Contributor
If this helps or solves, do you mind accepting as a solution?
Regards,
Venkat
Regards,
Venkat
