Opening hosted feature service in ArcGIS Desktop
2597
04-22-2014 06:55 AM
ErikSchliebe
I created a hosted feature service in ArcGIS Online and made some field collections with Collector.  Now I want to bring the features back into ArcMap and integrate the data into our normal geodatabases.  I have used the "Open in ArcGIS for Desktop" tool within ArcGIS Online, and the "Add data from ArcGIS Online" tool within ArcMap.  In both cases, I see the data in ArcMap, and I can Identify the data.  The problem is that I can't export it to a file geodatabase, or view the attribute table.  When I try opening the attribute table, I get an error message (see attachment).
Any ideas?
ErikSchliebe
I would still like to know if there is a way to access this data in ArcMap, but I did find a workaround.  I was able to export to a Shapefile from ArcGIS Online, and open that in ArcMap.  This allows access to all the data.
by Anonymous User
Not applicable
Hi Erik,
With the latest update you can choose to export the data to a File Geodatabase. This is done by viewing the Item Description for the Feature Service and clicking the export button > to FGDB.
Thanks!
