Not all features drawing/displaying/rendering in ArcGIS Online
3975
8
04-23-2018 11:31 AM
deleted-user-LNABNwA5CZcD
In ArcGIS Online, I have a shapefile of 300 polygon features (drainage basins) around the world.
A random few (can't figure out a trend) won't display. They're in the attribute table, but nothing displays on the map at any extent.
I tried both uploading the zipped shapefile package as well as sharing to the web from ArcGIS Pro. Same issue.
Why is the visual component missing; how do I fix this?!
Tags (1)
ChrisWhitmore
Hi Sam,
Is it possible to share the layer?
Chris
ChrisWhitmore
Great thanks! Sorry should have also asked - which features are you seeing that aren't displaying.
Colorado, Swedish Baltic, Tonle Sap.
Actually, I just tried something, and it might have done the trick. I exported and disallowed M and Z values. It seems to work now. I have no idea why only a few were affected given that everything was built from the same two datasets (one for domestic, one for the rest of the world). Odd that there were issues with polygons created from both.
AdrianWelsh
MVP Honored Contributor
Yep. That has happened to me before. Not having Z values has allowed my features to show up as well. (my thread from a year and a half ago). Not sure what this is but I have now disabled z values when I publish data to AGOL.
ChrisWhitmore
Sam Perkins ok great good to hear. The Ms and Zs change makes sense (when they are present, geometries are processed a bit differently in some cases. It looks like in this case, this resulted in null geometry for a few features). Adrian's suggestion should have worked as well - when running the repair geometry tool, make sure OGC is selected as the validation method.
If you're able and willing, it'd be great to contact support with this case and get an issue logged that we can look into further. Here is support's info: https://support.esri.com/en/contact-tech-support
thanks,
Chris
AdrianWelsh
Sam,
Try running a repair geometry on your features, then try uploading it again.
Repair Geometry—Data Management toolbox | ArcGIS Desktop
No change...
