No Data Classification using 2 variables in AGOL
1624
05-15-2023 12:13 PM
jfischer91
I'm trying to symbolize a polygon layer using 2 attributes in ArcGIS Online. One is a Yes/No status, the other is a numerical value. I want to display Graduated Symbols where the circle size shows the numerical value and the circle fill displays a Yes/No color.  So far, I can get 95% of what I want in about 3 different ways, each way lacking a different 5%.  I need the legend to be clear and correct since I'll be using it in an Experience.
Choosing 1 numerical attribute provides the Counts and Amounts option, where you can select your classification method, number of classes, etc:
But when you add a second variable, there's suddenly no option to classify your data, and you're left with Esri's standard options: Types and Size. There are two menu items to customize each variable: Types (unique symbols) and Counts and Amounts (size). Unlike the Counts and Amounts menu available above, in this menu, there is no option to classify data: you must choose a "theme": Above, Below, or High to Low. You can set the high and low values, but nothing else.
2-Variable Counts and Amounts
Why is it suddenly impossible to classify data when using 2 variables?  Esri's "themes" don't provide enough control to tease out variability in the data the same way other classification methods do.
I tried using an expression and manually setting the circle sizes using the Natural Breaks values, which seemed to work alright at one zoom level, but the Legend displays the pixel size of the circle, not the actual numerical value, so it's basically worthless to a map viewer looking for that value:
jfischer91_6-1684176367776.png jfischer91_4-1684176118608.png  jfischer91_5-1684176143725.png
I also tried using 2 versions of the layer stacked on top of each other, but that also leaves the legend looking incorrect.
Any other ideas on how to accomplish this? I ultimately want something like this, but with circle sizes using Natural Breaks classification:
ZacharyVavra
I too ran into this issue and echo jfischer91!
Esri, please allow the user to classify numeric data when using styles other than "Counts and Amounts (color)" and "Counts and Amounts (size)"! "Types and Size" and "Color and Size" are two styles which should definitely allow for classifying data (there may be others too).
Update! An enhancement request for this was submitted (# ENH-000164777).
