New Map Viewer - View Related data?
3322
06-30-2021 12:31 PM
by Anonymous User
Not applicable
When will it be possible to view related data in the New Map Viewer? In map viewer classic you just click on "Show Related Records" in the pop-up window and it opens the table view. (I would love the related records in the pop-up window, but that's another story).
I need to use the New Map Viewer because the map is for the Field Maps App that uses conditional visibility for some of my fields. But I can't use the New Map Viewer because I need to check the related records on my points. Interestingly enough I can view the related records in the actual Field Maps App. But I can't get the Field Maps App on a Dell Windows Tablet nor on my Windows desktop computer! ahh! Isn't that a fun circle? Do you have any other ideas for me?
https://doc.arcgis.com/en/arcgis-online/reference/limitations-and-compatibility-mv.htm
Oct 2020 https://www.esri.com/arcgis-blog/products/arcgis-online/announcements/new-tables-pane/
Thanks.
AnninaHirschiWyss
Showing related records in pop ups is really essential for me too. @KellyGerrow , can you give us some information when/if this will be possible? Or is there a workaround with Arcade? I tried with the "FeatureSetBy"-Functions, but couldn't get satisfying results...
FionaRenton1
 A year later it is still essential and not in the product sadly.
AndreaB_
OP here, re-subscribing with a new Community User name.
