New Map Viewer Stroke Width Broken!!!
972
03-17-2022 11:45 AM
neomapper
What is up with the stoke option in the style tab? When we use the Edit tool, add a point to the map, the stroke size will go from 0 to 72. All the points are crazy massive and clogs everything on the map. We can't evening deactivate this option as it's grayed out. Any ideas?
RhettZufelt
MVP Notable Contributor
Edit due to @RussRoberts pointing out where the symbol is.
I can't seem to reproduce either.  Is this a map service by chance?
Does changing the size of the actual symbol do anything?
R_
RussRoberts
Esri Notable Contributor
I cant seem to reproduce this using the same POI basic symbol. Can you share your map?
Thanks!
