New Map Viewer Pop-Up Custom Text Option - No Single Spacing?
1768
07-22-2021 07:48 AM
ChristopherBowering
Within the New Map Viewer, when I use the 'Text' option to configure a custom pop, there doesn't seem to be a way to set the spacing to single space (or change spacing at all).  I had to create the custom configuration in Word then paste it into the Viewer text window as plain text to achieve this.  Am I missing something?  I would think that spacing is a pretty basic formatting component.
AntoinevanEsch
There is an easy way to remove the spacing. Go to the HTML section in the text pop up. Remove for example the highlighted area as you can see below and add <br> between the parts. Now the spacing is removed.
Hope this will help 🙂
DavidAdelsberg
Exactly what I needed, thank you!
