new map viewer: drag and drop layers to reorder them no longer working
941
04-10-2025 07:40 AM
L77
In the new map viewer in AGOL I used to be able to drag and drop layers in the interface to reorder them.
This morning it isn't working and I have to click on each layer and click Move up or Down.
I am working in Arcgis Online, using Firefox. The move icon with the 4 arrows shows up but the layers won't move by dragging.
Is this "by design"?
RussRoberts
Esri Notable Contributor
This looks to be an issue with a recent update to Firefox 137(not 136). It has been reported to FF and it is being looked into.
RussRoberts
L77
Thank you for letting me know.
I am using firefix 137.0.1:
Tage
by Esri Contributor
If I use say for example StoryMaps, then I can move the elements up and down i Firefox, but not in Map Viewer, someone know whats the diffrence?
RussRoberts
Map Viewer is using Calcite for our layer list which has the issue related to firefox and should have a fix rolling out with firefox 138. You can see the issue here with this sample when you set the property dragable to true https://developers.arcgis.com/calcite-design-system/components/list/
ChrisMagnuson
This is not an official answer, but I am noticing that this issue appears to be resolved  for me on Firefox version 139.0. I hope this helps.
