Modify the symbolgy of a source layer in AGOL
804
04-09-2025 03:18 AM
CarlaNardinocchi
Hi all,
I have a group of layers in AGOL that I have published from ArcGIS Pro, where I have also defined style and symbology.
In my web map I have changed the symbology of one of the layers, but when I use the EDIT widget (in Experience Builder) acting on this layer it always refers to the symbology of the original map.
I discovered that it is connected with the symbology of the source layer I shared from ArcGIS Pro.
In the information pop up (see attached figure) I cannot disconnect the symbology of the source layer: "Proprieties cannot be  reset because they are already referenced from the source layer"
Moreover, if the disconnection had worked, I also wonder whether I would have lost all the relationship of the source layer or not.
The only solution is to start from beginning my already advanced project!!!!
Thansk for any help!
EmilyGeo
Hi @CarlaNardinocchi
If this is regarding Editing, you may need to update your templates. You can now do that in Map Viewer following these steps:
With the layer selected in the Layers pane,
  • Click Configure editing.
  • Choose Templates
  • In the Templates window, click Update in order to sync the new styles to the templates.
  • Save and close the Templates window.
The updated Template(s) will appear in the Editor pane in Map Viewer and the Edit widget in other apps like Experience Builder.
JohnEvans6
I think I had a similar / the same question last year and unfortunately the answer seems to be "republish from Pro to update the symbology".
Re: Editing a Layer Style/ the drawingInfo in ArcG... - Esri Community
EmilyGeo
  • Choose Templates
CarlaNardinocchi
Thanks for the tip and for the hope that I can solve this problem without having to do it all over again.
I don't know if this relates to editing. I know that when I use the Edit widget in Experience Builder, the original style of my layer (source layer) that was imported from ArcGIS Pro comes out (it was a mistake to set all the style in ArcGIS Pro!!!?)
Here is what I am doing.
The source layer is based on a 'Count and Amount (Colour)' and I had defined 3 categories, each with a different colour.
In AGOL's map viewer I change the style of this layer to Single Symbol (unique color). I save it.
The map changes its layout and I now have a single symbol. The legend shows: the name of the single symbol layer and the point.
I now follow your instructions:
Click on Configure Editing
Choose Templates : here I see the 3 categories but all with the same colour of the syngle symbol.
I cannot find a way to change the template and/or Update.
I have removed 2 of the 3 categories, but:
- I MUST enter a name to be displayed
- and my changes are invalid
Thanks again for any help!
CarlaNardinocchi
Hi @EmilyGeo
I take back what I said.
I went ahead despite the error in saving.
I left 1 template, entered the name I wanted of the layer and the widget in Experience Builder was correct.
Thank you very much!
