Modify the Popup heading
7275
8
09-18-2018 09:13 PM
by Anonymous User
Not applicable
Hi GeoNet Users,
Is it possible to change the Pop-up heading (e.g. make it bigger)?
Also is it possible to modify the pop-up (e.g. remove the line but also place the pop-up heading at the top of the pop-up window (see attached).
Chris
JoeCatanzarita1
Hi Chris!
As Shantonu suggested, HTML is a good way to play around with Pop-Up structure! I would also recommend looking into Arcade Expressions as a way to further customize your Pop-Ups. Personally, I don't have much experience with these types of expressions, but here are two links you can reference if you're interested.
After reading your post, I ran a quick test.  If you're interested in getting rid of that black line in the Pop-up, or if you're interested in increasing the size of the title, something you can do is delete the Pop-up Title as a whole and work strictly with the body of the Pop-up. Deleting the title will remove the black line separating title from body and you can then configure the body of the Pop-up to look as you wish. Refer to my screenshot as an example.
Best of luck!
Joe
shan_sarkar
Chris,
You can play around with the pop-up headers with the basic HTML tags.
e.g.
<font size="16">This is some text!</font>
<b>This is some text!</b>
<i>This is some text!</i>
I hope this helps!
I am not sure if I follow the second query that you have posted. Can be a little more specific on the requirement?
~Shan
~Shan
by Anonymous User
Not applicable
Thanks Shan that has helped! I am also trying to change the pop-up so the line below the heading is not there but also have the heading display at the top of the pop-up much like the 3rd screenshot in my attached document.
Chris
shan_sarkar
Chris,
Any chance that you are referring to the line highlighted within the red box?
~Shan
~Shan
by Anonymous User
Not applicable
Thanks Shan. Yes I would like to take that line out. If you see Joe's response below he explains how it can be done. From last piece of the puzzle is to move the title (e.g. Roadworks) to display in the blue area of the pop-up. You wouldn't happen to know how I could do that?
shan_sarkar
Chris,
I would need to play around with what Joe has suggested to see how it affects the line. But it's good to know that there is so much customizations available with AGOL.
~Shan
~Shan
JoeCatanzarita1
Hi Chris!
Best of luck!
Joe
by Anonymous User
Not applicable
Thanks for your help and the links Joe really appreciate it!
AdrianWelsh
MVP Honored Contributor
Chris,
When using HTML in popups in ArcGIS Online, it is good to be aware of what is supported and what is not. This article lists what is supported for html operations:
Supported HTML—ArcGIS Online Help | ArcGIS
