Missing Polygons in Layers Published in ArcGIS Online
2695
6
10-26-2023 02:16 AM
jantolihao
Hello, everyone!
Has anyone encountered an issue with missing some polygons of layers published in ArcGIS Online?
Here's the scenario:
Left Side: This is the original data stored in file geodatabase.
Right Side: This is the data published in ArcGIS Online.
Notice that after publishing the layer in ArcGIS Online, some polygons are missing. Before we publish the data, Check Geometry and Repair Geometry were performed. We have also tried overwriting and/or republishing the layer, but displayed the same result.
I appreciate any help or hints regarding this concern. Thank you very much.
RussRoberts
Esri Notable Contributor
Can you share the sd file and I can take a look.
jantolihao
Hi, @RussRoberts.
Thank you for the response. Here's the web layer's SD file.
RussRoberts
I just published it from Pro to my org and it published it correctly. I didn't see the missing feature in the gdb within the SD as well. Do you see the record in the table in the hosted layer?
https://jsapi.maps.arcgis.com/apps/mapviewer/index.html?layers=0dd4471d5a2c45d0bdfffdb99dabd1c8
jantolihao
Hi, @RussRoberts.
Yes, I forgot to mention that the layer is visible in the Map Viewer/Map Viewer Classic in ArcGIS Online. However, when tried to view the published layer in ArcGIS Pro using the Portal tab, it has a missing polygon (please see screenshot). I am using ArcGIS Pro v.2.9.5.
JacquelineHamilton2
Hello,
I am having the exact same issue utilizing ArcPro 3.1.2.  The polygon feature layer pushing to Portal removes two polygons from my dataset. And interestingly enough, when I look at the feature layer the next day it  displays a different missing polyone and the original missing polyon is filled in.
Was there a solution to this issue?  Even when I bring it back into ArcPro the  polyones are missing.
SamuelSkinner
I had the same symptoms on AGOL after publishing from ArcGIS Pro 3.2.2, the same few polygons missing from the published layer. I found this much-older post: https://community.esri.com/t5/arcgis-online-questions/published-feature-layer-missing-features/td-p/... that suggests that too many vertices cause problems in AGOL. I should think that Analyzing the layer prior to publication would catch that problem. Anyway, I exported directly to a GeoJSON file. After bringing that it, all my polygons were in there, without their symbology.🙄
