MapViewer Arcade Popup Chart Only Rendering as Piechart
354
12-27-2024 04:01 AM
AustinAverill
I have a webmap I am attempted to set up a new pop-up element within. I have wrote in the following code, however it will only fully render if I change the type to piechart. Otherwise it only renders the background of the chart area but none of the data. I use the same code to also populate a fieldlist from the data in the same fashion and this works without fail.
Any ideas or suggestions would be welcome.
var use = FeatureSetById($map, "19403d43feb-layer-16");
var ptr = $feature.PTR_str;
var spec = Filter(use, "PTR = @ptr")
if(Count(spec) == 0){
  return {
    type : 'text',
    text: 'No Usage History Available'
var spec2 = OrderBy(spec, "bill_date ASC")
var mos = Dictionary({
  '0' : 'January',
  '1' : 'February',
  '2' : 'March',
  '3' : 'April',
  '4' : 'May',
  '5' : 'June',
  '6' : 'July',
  '7' : 'August',
  '8' : 'September',
  '9' : 'October',
  '10' : 'November',
  "11" : 'December'
var atts = {}
var fldIns = []
var flds = []
var mo
var yr
var nm
var usage
for(var row in spec2){
  mo = Text(Month(DateOnly(row['bill_date'])))
  yr = Right(Text(Year(DateOnly(row['bill_date']))), 2)
  nm = `${mos[mo]}${yr}`
  usage = row['billed_usage']
  push(fldIns, {fieldName : nm})
  push(flds, nm)
  atts[nm] = usage
var element = {
    type: 'media',
    // title : 'The title for all media in the element',
    // description : '',
    attributes : atts,  // replace this dictionary with your own key-value pairs,
    mediaInfos: [{
        type : 'linechart', //linechart | barchart | piechart | columnchart
        //title : 'give your chart a title',
        // caption : '',
        altText : '', //altText will be read by screen readers
        value : {
          fields: flds,  // choose what attributes to use in the chart
          /* colors: [  // values must be an array of [r, g, b, a] values (0-255)
            [122, 190, 229, 255],
            [179, 155, 213, 255],
            [248, 174, 131, 255]
          //normalizeField : '',  // the name of the attribute to normalize by or value
  return element
