Mapping Out ZIP Codes From Survey
3215
04-13-2023 11:01 AM
OKCParksRecHolly
Hello!
I have created a pretty basic survey to get the satisfaction levels of participants in our recreation programs.
In this survey, we collect the home ZIP code of the participant so we can get a rough idea how far folks travel to attend their recreation program. The ZIP code question is a Singleline Text with an input mask for ZIP codes (99999).
I am wanting to create a dashboard that has a map displaying which zip codes have the most participants coming from them. However, whenever I try to map this in ArcGIS Online, I can only map where the survey was submitted from.
How can I map out the ZIP codes entered from this survey into something useful?
Thank you!
jcarlson
You're talking about performing  a join, basically. Get a ZIP Code polygon layer (I think the Living Atlas has one), then use the "ZIP" column to join the two together.
https://doc.arcgis.com/en/arcgis-online/analyze/join-features-mv.htm
Your survey responses will then be aggregated and added to the zip code areas as new attributes, which you can then use for symbology options.
- Josh Carlson
Kendall County GIS
