Map Viewer Not Saving Map
2102
04-28-2023 09:19 AM
vg11
Hello everyone, I have been using Map Viewer regularly. Just within the past hour, after making some edits using Map Viewer, I was unable to save edits. it seems like a bug or maybe something is down with Esri? Has anyone experienced this? I am able to open the save option and select save but absolutely nothing happens. It does also seem like the left panel/ribbon with the layers, basemap, save button is almost disabled because I cannot toggle between layers and basemap. I tried clearing my cache, closing and opening on same and a different browser, to no avail. SOS
MobiusSnake
MVP Regular Contributor
Working fine for me at the moment.
vg11
No idea why but it was only happening to one of my maps. I ended up making a new one from scratch and just deleting that one. Very odd. I am glad it was a small map with just a few layers and not a bigger, more important one.
Paco
This has happened to me several times in the last month,  to several of my Map Viewer projects.   one I had to delete and rebuild(not fun),  and the other I actually did find a 'dependency' of a broken table that was originally part of the project.  deleted it,  and could then Save again.
still,  this definitely seems like a 'buggy' issue.
g_maps
This issue is similar to one I've been experiencing. Several filters and pop-ups I've configured weren't committed to my map after saving in Map Viewer. Sometimes, a red error message appears saying I need to close the filter pane before saving, and the save button freezes for a couple of minutes until I can try again. Sometimes the save won't throw an error, but when I revisit the map to make additional edits, the changes I made prior are no longer there, and I have to redo the work.
