Does anyone have any suggestions for making new Map viewer not be so slow?
This seems to be a recurring issue. I like a lot of Map Viewer's functionality, but I really am having a hard time waiting for it to do anything.
It is painful to try to make any changes to a map, such as filtering or changing symbology. Forget editing. I understand it on maps with a bunch of stuff, but it's even affecting setting visualization for feature classes on their own item page. I just set symbology for an empty feature class and it took forever to load. I do not mean the map, I mean each menu when you click on it or make any changes.
I'm also confused because all of the applications that use the maps don't seem to have any slowness? Collector/FieldMaps has no problem, for example. Just Map Viewer seems to be slow.
If anyone has any tips for making it not so slow, I'd appreciate it. Thanks!
No suggestions, but we have been troubleshooting the same problem with Esri support team. We have started suggesting people use Field Maps as a workaround.
Can you share the map and we can take a look?
Hi Russell,
I don't have a map that's shareable right now, but I did some testing. To be honest, this issue might just be a limitation of the tech.
Another thing I'm unsure of is if Map Viewer runs better on some browsers or not, and how much that might be causing my issues.
I'm using Edge (I know) since that's what we use at work, but if it runs better on other browsers, I'd appreciate knowing about it. Maybe this would all get better if I just switched to Chrome or Firefox or something.
I'm spoilering the timing that I think is just par for the course. I'm not sure how much can actually be changed.
These are the two things that I think can be changed.
I do want to reiterate that I do understand that sometimes things just take a while to happen. There's a lot of stuff going on in Map Viewer, especially when you have several different layers all doing different things. When it works, it works great. My complaint is just how long it takes to get there.
Yup definitely will need a copy of the map to help assist looking into it. If you can pop the map and layers into a group and invite russell_jsapi to that group and I can take a look.
how many layers in the map are you using? What types of layers are you using?
Are you using edge or edge(chromium)?
Thank you to @Ole_MariusGulbrandsen for poking this thread.
I'm using Edge (Chromium).
Layers vary. My project map has upwards of 30, but again, this lag also appears on the visualization tab of individual item pages. It makes sense to lag with 30 layers. It doesn't for one.
It's also worth pointing out (and most frustrating), that this lag occurs (on the Visualization tab), in layers with ZERO records. Seriously, make a new feature class, any number of fields, and before you populate any records, try setting a default visualization. It is sloooow, which is baffling because there's nothing for it to render.
I unfortunately do not have any maps that I can share other than just creating an empty feature class to play with.
We also have the same problem with the new map viewer 🙄 Everything seems to work fine in the old map viewer and/or web app builder. We started to use the new map viewer and experience builder because we wanted to group layers and make use of all the new widgets in EB. Now all of our bigger project running on the new map viewer and in Experience builder are so slow. I do not want to convert back to the old map viewer and webappbuilder, because we really like and find the new funcionalities in EB and new map viewer very useful.
Link to two of our road project running on EB and new map viewer:
Old project.
https://experience.arcgis.com/experience/3c016ede34fc4936a91bd33c17f3b5c1
New project:
https://experience.arcgis.com/experience/4f40ac3daaad4eb197c39189b53052e5
Are you seeing Map Viewer behaving slow or Experience Builder? I checked the load times for the maps in Map Viewer and was seeing 3.5-4 seconds with both maps from the 2 different experience builder links. Map Viewer Classic was showing roughly 4-4.5 seconds for me.
Both, Experience Builder and the new map viewer are slow in mye opinion. Turning on and off sublayers, using the draw and print widgets. Working with the symbology, labels etc on the map layers, moving around in the map and more. For me this works so much quicker in the old web map and web app builder unfortunately.
Link to both of the projects web maps:
