Map Viewer Does not Change Image Service Processing Template
1523
02-27-2023 11:25 AM
GBacon
I have an image service that uses two processing templates to show elevation as a hillshade and shaded relief. The map viewer doesn't seem to recognize the "None" option, so it will not draw the black and white digital terrain model even when I select it. I tried authoring the map in the classic map viewer and reopening in the new map viewer but it's defaulting to hillshade and I can't change it. Note: the hillshade processing template is the default.
Here is the image service: https://www.fairfaxcounty.gov/nadar/rest/services/LiDAR/2018_LiDAR_Digital_Terrain_Model/ImageServer
RussRoberts
Esri Notable Contributor
We should have a fix for this rolling out tonight and you can check it out tomorrow.
RussRoberts
Thanks for reporting. We are looking into this.
GBacon
Thanks for checking it out.
RussRoberts
GBacon
The processing templates work now. Thanks for the quick response!
