Map Viewer Classic Filter by Field Not Available
596
05-05-2021 08:43 AM
kkoz490
Within Map Viewer Classic I am not able to filter by field. That option is grayed out. I do have the options for Value and Unique. Has there been a change in the new map viewer that dose not support filter by field?
Thank you,
Kevin
JayantaPoddar
To enable Field option in Filter, the layer should have two or more fields of same datatype.
e.g. Field option is disabled, since the layer has only one Field (District Name) of TEXT Datatype.
But the layer has multiple fields of LONG Datatype.
Think Location
kkoz490
Hello Jayanta,
Thank you for your reply. I will double check about the field types. I am trying this in a joined layer. The two fields I am trying to compared are of the same data type.
Kevin
