Map Image Layer in Legend
1418
04-22-2024 02:57 PM
MeKohler
Hi, when using a map image layer, is it possible to just show the layer name in the legend?
I would like to see this.
Instead of this:
I don't know if I'm using the correct terminology,  but I would like to hide the map image name and just keep the layer name.
Tommi
I was able to find out that you can change the layer name of the MabServer (Rural/Agriculture - written in bold in your screenshot) using the ArcGIS Online Assistant. Here I was able to enter a space in the name in the JSON of the WebMap configuration and the name disappeared. This should give you the visualisation you want.
Another option is to integrate the desired layer directly into the map using the REST URL. Then the legend will also be displayed as you want it.
Tommi
